Old 09-16-2007, 01:36 PM   #1
Mudstud
Treasurer
Mudstud's Avatar
Images: 9
Send a message via AIM to Mudstud
XJ Mods
Im taking the XJ over today to T.K.H. Fab.
Terry is going to install a new rear end with Chrome-Moly 30 spline axles w/ 456 gears and a Detroit Locker.
He is going to tear down my front end and install a solid axle and new 456 gears with a Aussie locker.
This should be finished in a few weeks and i should be ready for the upcoming trip to Harlan,Ky in mid Oct. with the club.
Can't wait tp try out the new set-up!!!!!!
Mudstud is offline   Reply With Quote
Old 09-16-2007, 10:09 PM   #2
Terry does great work. You will be very happy.
Old 09-16-2007, 10:30 PM   #3
JET455
JET455's Avatar
Are you having Terry do his long arms one it?
Old 09-17-2007, 07:51 AM   #4
Terry from T.K.H. does excellent work! Both Brody and myself made it up El Diablo in Swiss WV last weekend and the local clubs haven't attempted the trail in a long while. Terry has done alot of impressive work on Brodys rig and it was punnished all weekend long with no problems! Very impressive steering and suspension setup.;)
Old 09-17-2007, 05:22 PM   #5
Mudstud
Treasurer
Mudstud's Avatar
Images: 9
We talked about the long arms and a new rear bumper with a swing away tire carrier. Have to pay for drive line first and decide if im going to Moab in three weeks. Can't decide what i want to do!!!!!:confused:
Old 09-17-2007, 05:30 PM
Mudstud
This message has been deleted by Mudstud.
Old 09-17-2007, 06:44 PM   #6
Decisions, decisions, decisions...
Old 09-17-2007, 06:51 PM   #7
The problem with the axles now will be the ring and pinion which are hard to repair on the trail. Better to keep the weak links easy to fix. The 8.8 is a very good option and cheaper and stronger than a built dana 35.
Old 09-24-2007, 09:55 PM   #8
Mudstud
Treasurer
Mudstud's Avatar
Images: 9
Terry said he was putting in new ring and pinion. Are there heavy duty R/P or they all the same quality.
Ordered the custom bumper w/swingaway tire carrier today and a set of custom lower control arm mounts. The OEMs were trashed. It should all be ready for the run on the 19th.
Old 09-24-2007, 10:16 PM   #9
Yukon and some others are stronger but the size of the gear compared to the dana 44's or 60's is substantial. It will probably be fine! I just tend to worry.
