On board air set - York Compressor and 4.2 brackets
York compressor and brackets for 4.2 I-6 brackets
York comp #'s on metal tag No. M 582778 Pt. AMC 5461585 Navistar Comp #'s on metal tag (Navistar is for International Trucks) No. A 2052077 Pt. 2000820-091 Bracket bolted to the compressor P/N 3230389 Cast Alum brkt 3242191 Small slot brkt 3238456 large bracket and pulley have no visible part #s on them Both compressors turn free, and the York has reusable fitting on the top so that saves you $ you don't have to buy fittings. I don't think the Navistar compressor has ever been use and all the mounting holes look identical to the York. I bought this used and never installed it so I cant tell you any more about it than what you see. $120 for York and all brackets $40 for Navistar compressor only. Thanks (937) 658-4704 I am looking for a CJ PSC steering box drilled for Hydro assist, lines and a remote resivour those are the only thing I will trade for. Last edited by U-Jt.Snapper; 09-03-2012 at 05:49 PM. Reason: trade updated |
