Old 10-23-2012, 10:58 PM   #1
spurdog
slave cylinder bleeding
Got a 95 Wrangler, 5spd 4cyl. Just got the transmission back in it and it has no bleeder on the slave cylinder. Wandering what the best way to bleed it would be. Thanks for the help
spurdog is offline   Reply With Quote
Old 10-24-2012, 07:34 PM   #2
flatlander757
Fartface extrordinair
Most efficient way I've found is to remove the slave/line/master as one big assembly, and hold it so all the air goes up and manually pump the master a few times.
The factory Chrysler way for many of their vehicles with no slave is to basically top off the master and pump the clutch pedal 200 times... check again, then repeat. It's a mother****er bleeding a Viper clutch line
