10-25-2012, 12:04 AM | #1 |
strange popping in rear end
ok folks i worked on this sami all last week and it is still popping in the rear end..
here is what i did. 1. it had 4.62 gears - pulled pig and locker was trashed.. so i figured time to swap in the 5.38 gears which i had in another axles set from splattt. 2. swap front axle out with 5.38. 3. put in 5.38 pig with locker in rear. 4. rear left side still popping when turning or gettin on the gas going straight.. At this point im thinking the lockers are bad... called up lowrange - they said lock rite lockers are out of business 1530 lockers are no more... so I ordered a spartin locker and side gears...next day air got it thursday morning and put the new locker in the 5.38 looking at old locker it looked ok and did not have any chips or rounded corners on the locker so i set it aside.. put everything back together.. 5.38 in axles. still popping... thought maybe it is the axles shafts... or tcase.. pulled axles and put in new ones. still popping said ok lets swap put the old locker in the 4.62 gears set and see what happens.. put it in the axles and still popping.. lifted the axle off the ground and spun the rear in gear and it popps on the left side.. so as it sits... 2 separt 3rds both with 2 different lockers. both are popping on left. 5.38 - new spartan locker 4.62 - old lock rite with new side gears new springs Im at a loss as to were to go from here unless i set up the lockers wrong.. but i followed the specs sheet.. :confused::confused: oh yeah this is the reason I missed fall crawl... 5 people can not fit into 3 SEATS.. NEEDED BOTH RIGS.. Gatlinburg is where we went... tried to make the best of things...
Thanks, 67fastback ------------- 84 Honda cr60r - for sale 87 Honda 200sx - for sale 67 Mustang fastback - under restoration MCA #63430 04 Silverado 2500 crew cab 87 sami - "SPLAT" 87 sami tin top - "Blue Fire" 88 sami - "Squirt" My New Video Channel -http://www.youtube.com/PhillbillyProduction My Video Channel - http://www.youtube.com/justworkn Last edited by 67fastback; 10-25-2012 at 01:03 AM. |
10-25-2012, 07:13 AM | #2 |
It sounds like it needs piston rings .and a fuel pump.
my next rig will be on the trail before zuk 2.0 will |
10-25-2012, 07:33 AM | #3 |
Bearings in outer axle or breaks?
10-25-2012, 08:04 AM | #4 |
- Moderator - |
I also say axle bearing, I had one do this before on a Toyota which I believe is the same setup. Pull the axle- an ok or new one will have slight slop in it, if it has any more than slight then its junk. Trust me you will be able to tell, a lot of people overlook this.
No need for a Winch...You just have to make it !! |
10-25-2012, 08:44 AM | #5 |
Sounds like you"ve been eating Mexican food
I got a jeep |
10-25-2012, 09:46 AM | #6 |
Take the wiper motor apart and u will find your problem
S10 with a few air shocks.. |
10-25-2012, 10:12 PM | #8 |
I would change the oil and adjust the seat first
10-25-2012, 10:23 PM | #9 |
too much air in your left front
10-26-2012, 02:44 AM | #10 | |
yeah I will have to check this..
thought that too... but all in all I can swap out the axle housing also and try that after checking 3rds and axle bearings...
Thanks, 67fastback ------------- 84 Honda cr60r - for sale 87 Honda 200sx - for sale 67 Mustang fastback - under restoration MCA #63430 04 Silverado 2500 crew cab 87 sami - "SPLAT" 87 sami tin top - "Blue Fire" 88 sami - "Squirt" My New Video Channel -http://www.youtube.com/PhillbillyProduction My Video Channel - http://www.youtube.com/justworkn |
10-26-2012, 06:44 AM | #11 |
Can someone else drive it while u walk behindand determin if sound is from pumkin or the side?
10-26-2012, 08:10 AM | #12 | |
maybe ill have to make a video....lol
