Old 10-31-2012, 09:07 PM   #1
4wdOwnage
4wdOwnage's Avatar
91 Geota
1991 Geo Tracker/Toyota Crawler 1.6l 8v, RingR adapter, Toyota transmission with dual twinsticked top shift transfer cases with a TG adapter, rear tcase is mounted with super duty mount with poly bushings, and crawl box is mounted with a stock mount both to a huge custom cross member.
1985 front Toyota axle, Dirty 30 chromoly Axles with receipt, Geared 4.88 with larger IFS 4Runner calipers, 5th knuckle stud, Trail-Gear hi-steer arms, 3” wheel spacers, diff armor, and gusset. Double cardigan drive shaft.
1987 IFS 4Runner rear Toyota Axle, geared 4.88 with Trail-Gear 3” wheel spacers, diff armor, and gusset. Rear 4runner drive shaft.
Trail tough rear driveline disconnect and electronic line lock connected to the rear brake lines for front digs. Stainless steel brake lines at the axles.
102” wheelbase 4 link rear with 7075 aluminum link bars on 16” 2.0 Fox air shocks, 48” Hi-lift jack.
PSC Full Hydraulic steering with .250 wall DOM tie rod. Warn M8000 winch on the front, 3000lb cinch winch on the rear, full exo cage, bumpers, many tow points and hooks.
RJS 8 gallon fuel cell with large cooler securing. 2 cloth racing seats with 4 point harnesses in the front fit 2 adults comfortably and a 3rd plastic seat in the rear works good for a kid.
dual 5.25” speakers, and an Orion 12” subwoofer (no amp currently). CB Radio with a large antennae and Currently has TG 3” lift springs in the front with Marlin Crawler u-bolt flip kit installed.
HID Headlights, backup lights, and LED front marker lights. CB Radio, PA speaker, large antenna, mount for flag, 4 sound horn, heat works good and is very reliable. Many spare parts like a full set of Toyota axles, transmission, transfer case, spare stainless brake lines, spare tire etc.
$6000 obo
Reason for sale is that I would like a newer side by side like a RZR-S that would get more use around the narrow trails near home. Also have a 2006 Rhino Special Edition that I may be willing to trade both for a nicely equippped RZR-S or plan on selling both and buying a new one.
http://cincinnati.craigslist.org/cto/3352385044.html
91 Geota Exo'd on 35" Tractors etc.
06 Rhino 660 SE
Courageous Offroad Ministries
http://www.facebook.com/#!/pages/Cou...27565957345163
4wdOwnage is offline   Reply With Quote
