Old 11-27-2012, 09:31 PM   #1
Jonesy
Jonesy's Avatar
Drive shafts. DIY vs shops
Need a new front drive shaft for my Toyota. The one I just slung out was a square tube shaft I threw together just to get on the trails. The factory slip isn't long enough any more.
So my questions are. Are there any reputable drive line companies in the area that don't think their stuff is made of gold? Should I just buy one of the DIY kits from Marlin, trail gear or the like? This is off road only so it doesn't need to be balanced.
Anything else that I should take into consideration?
JT Jones
83 Toyota - beater
87 Toyota Truggy
Old 11-27-2012, 10:41 PM   #2
Todd can build you one. Worth a call.
Old 11-28-2012, 12:27 PM   #3
I prefer making my own and saving $$$$$
Old 11-28-2012, 12:47 PM   #4
Jonesy
Jonesy's Avatar
I'm right there with ya. The stock toyotas only have about 5" of usable slip. I need about 6-7" of slip. Anyone know of a factory slip that I could repurpose for my yota with enough slip? Really hate to spend $150-$250 for just the spline kit from anyone.
JT Jones
83 Toyota - beater
87 Toyota Truggy
Old 11-28-2012, 06:36 PM   #5
Do you have a shackle reverse? Why else would you need so much slip?
Old 11-28-2012, 07:48 PM   #6
i dont use 2" mayb of slip with 17" coilovers, i figured it was a leaf spring thing
Old 11-28-2012, 09:08 PM   #7
Jonesy
Jonesy's Avatar
I may have something set up wrong.
Current setup is a single case that has been tucked, RUF springs. Tried lengthing the stock drive shaft 2". It will fully compress the slip and pulls apart when it flexes out hard. All I know that is wrong is I need some degree shims to get the caster corrected, but that shouldn't effect the slip length. Any ideas?
JT Jones
83 Toyota - beater
87 Toyota Truggy
Old 11-28-2012, 09:33 PM   #8
the natural moion of leaves causes the need for exta slip.
as leaves droop out, the axle will move forward as well as drop out, both will increase the length of the shaft. when it compresses the axle will move rearward as well as up, both of which shorten the shaft needed. between the two phenomenon alot more slipp will be used with rear-shackled leafs.
with Links, the natural arc helps combat this as the axle does the opposite. as you droop, you axle moves back and down and under compression moves up and forward so the length of slip needed is decreased greatly with links over leaves.
Old 11-28-2012, 11:35 PM   #9
The natural motion of leaves set up in a shackle reverse type suspension will do that,which is why I asked, but after I reread the first post I saw it was a Toyota so it probably is shackle reverse. If that is the case I'd order a long spline kit and make my own drive shaft
