Hmmmm I thought he lived around here.
Announcement
Collapse
No announcement yet.
Hvac
Collapse
X
said he lived in harrison
jacked with the pressure switch
seems to be working, getting correct volts anyway
started jacking with thermostat and it started working againFor you guys who can't drive, I have owned a frame rack for several years. Prices are based on your skill and ability to wreck it....
hvac dude here. back of your furnace doooor should have a chart what those codes mean. if it is your pressure switch not making, check 2 things. when your furnace is tying to light but failing, take your front combustion air (burner) door off. if it lights now, that means youve got a restiction in the intake pipe. leave, birds nest, ect. dosent light? try to clean your trap. if your furnace is a 90% or more, youll have tubes going down from below the inducer motor to a cannister(trap) before out to the drain. take it off and flush it in the sink. make sure you have it primed with water upon reinstall. hope it helps, rob. ive got to pm you about some other stuff, anyway. robmy next rig will be on the trail before zuk 2.0 will
