Originally posted by underpowered
View Post
Before & After - My 1993 K1500
I'm really interested to see what you come up with as I'm in the same boat. I like the K5 but simply having a smaller body seems like it would make most trails a little more enjoyable as you don't have to worry about snaking in and out of trees as much....the tires would still be the same width but at least you wouldn't have to worry about the body as much.
Not sure on the weights but wouldn't think you lose much between the fullsize regular cab and S-10 extended cab considering most of the heavy stuff (frame, drivetrain, etc...) all stays the same.
This is the reason I like my truggy so much. It is a full tube chassis but still has a toyota cab and dog house. Seriously thinking of starting a new chassis with the same concept but with a few changes to suit my style better.JT Jones
83 Toyota - beater
87 Toyota Truggy
I'm not sure your gonna save weight by going to an ex cab s10 cab... I have a cab if u wanna come measure on it... It's a heavy pig... If u wanna save weight get rid of the full frame and do a tube frame it makes a world of difference... The green ex s10 I built that I posted pix of a while back had some of the original frame and time I plated it up to be strong enough for the links it got real fn heavy... My current rig/build is a full tube chassis reg cab s10 with tons and its gonna be MUCH lighter than the ex cab I built for my buddyS10 with a few air shocks..
Your engine, axles, frame size are what's killin you on weight, my rig weighs in at around 3500 Lbs, start downsizing on axles & motor, besides its your weight that will hold you back or brakes you in the first place. Just my opinion...No need for a Winch...You just have to make it !!
Originally posted by humpy View PostEx cab linked both ends makes for LONG wb... My buddies is 12 9 and be tough to get it much shorter and still have good approach/departure angles... Mind is 116" and right where I wanted it
There are things I can do now to save weight. I know my stock doors are heavy. There's an easy 150 lbs. I just don't know if it's worth it to build a whole new rig to save 500 or so pounds.
If you don't mind, could you throw a tape across your rock sliders and let me know what it is. If what I read online was correct, my cab is only 8" wider than the s-10. That doesn't sound right. Thanks
Originally posted by Runoveru2 View PostYour engine, axles, frame size are what's killin you on weight, my rig weighs in at around 3500 Lbs, start downsizing on axles & motor, besides its your weight that will hold you back or brakes you in the first place. Just my opinion...
Originally posted by humpy View PostYea ill measure tomoris mornin when I'm at my shop... Those are tons and 43s ...it will be fairly low for a truggy rig... 23" belly and 76" to top of cage...
Originally posted by Redriverranger View PostMine is over 5000, I am sure. Ext cab small truck, wheelbase=131. You have to ditch a lot of creature comforts and tools/parts to get the weight down. Good luck. A thousand pounds is tough.
Originally posted by twiztedzuki View PostThat is my thoughts exactly!! more motor!
Cab buggy is best of both worlds.
having a large rig on tons and big tires but keeping it light is tough.
i want to weigh my beast, i am betting about the same as your truck at about 5200lbs or so. it is wider than your truck though, slider to slider is 80", but belly is 24 with an 84" roof height.
my next ride will be all tube, either with cab, or even just full side panels.beat up rusted out k5
