I am able to run 9lbs. in 42'' bias ply irocs at 65mph with no problems. Not balanced and amazingly smooth. Not sure why but maybe lucky or something.
Balance A Super Swamper I need help
Originally posted by cincykid View PostWhat kind of pressure do you run in them for street driving?
I have 33x13.50.15 S S Ltb's
I always heard to pump them up to suggested and then when on the vehicle run them thru water and then to dry concrete. Continue checking and decrease pressure until you get a good even tread contact across the hole tire. Front and rear may be different due to weight differences.1994 YJ, 4.0, 5 speed.
air pressure
start with about 23 -28 psi and drive it then look at the contact patch of the tire and adjust from there. if you put to much air in the rolling resistance will be good for milage but not the tire wear in the center.One of these days Zuk 2.0
They have BB's in a smaller form for motorcycle tires and those actually can go through the valve stem but come in 1 ounce pack and would take for ever and too much money to put in to some 36's Sarge.88 XJ - 5" lift - 35" BFG's - Bumpers - Rock Rails - Homebrewed OBA - Roof Rack - Tube Doors - Trimmed - Dented
I had regular steel BB's, maybe 2-3 oz. (also had rim weights), in the 265/75's on my DD/towrig and never noticed them at all. Currently I have maybe 10-12 oz. in my 39.5's on my Blazer and never noticed them with the top off (half top) and the doors on even with window down, but once I took the doors off for the summer you can hear a small "swoosh" right before you come to a stop while driving through town or the neighborhood. Never notice them on the trail at all.
Even if you can fit them through the valve stem it would take a long time to feed them in one at a time because you are talking about hundreds, if not thousands, per tire.
Originally posted by 4RunnerAdam View Post
Should I keep the wheel weights that are on there now?
So, should I? Do I need to take all the lead weights off? I'm guessing so.
Originally posted by 4RunnerAdam View PostShould I keep the wheel weights that are on there now?
I'm lazy, and would just leave them on. But they are ugly, and you don't need them anymore, so if you want to pull 'em, pull 'em...
RobertDIRTY DEEDS, DONE DIRT CHEAP
The last time I did a set the wheels never came off the Blazer. It was as simple as jacking up the corner your working on , let air out , cut stem off with side cutters, fill with guestamated amount of Daisy BB's , dip new stem in Dawn dish soap and wrestle that ***** back in.
Only works with steel wheels though.
Originally posted by maddhatter View PostCan't you just pull the valve stem center out and put them in that way without unbeading the tires?
Pulling the tire off and debeading it is pretty quick and easy. Take it off the truck, use a Hi-Lift under the bumper of a truck to push the bead off, dump in the BB's, air it back up.
if its a dd or drove on the road much use the airsoft bb's over the copper reg bb's because i shot peen'd my rims with the cooper ones and it was a DD they make the air soft in different weights get the heavy's and it should work out great94 yj 4.0 HO
header
cold air
stock drive line (for now )
