waggy 44's
Those knuckles look sweet and well designed but i can't see putting that kind of money in a D30.Ballistic Fabrication makes a mounting kit that welds onto a D44 that enables you to us all your XJ front D30 componets.Such as control arms,coil srrings,track bar etc.Seems like it is around a hundred bucks.This makes the swap a real clean setup.You'll also need to shorten the driveshaft since the D44 diff is larger.Ballistic Fabrication phone # is 520 888 4441 ,they are in Tucson,AZ. Hope this helps you deside on your axle swap.
