Is a 8.25 as strong as a Dana 44?
Announcement
Collapse
No announcement yet.
8.25 vs. Dana44
Collapse
X
The 29 spline is pretty close.
The 27, not so much.
Chrysler 8.25 (1991-1996)
• 27 spline, 1.17" diameter shafts
• 8.25" ring gear
• 3.00" axle tube
Chrysler 8.25 (late 1996-2001)
• 29 spline, 1.21" diameter shafts
• 8.25" ring gear
• 3.00" axle tube
Dana 44 non c-clip
• 30 spline, 1.31" diameter shafts
• 8.5" ring gear
• 2.75" axle tubeDIRTY DEEDS, DONE DIRT CHEAP
Tony, what is in your XJ now? The 8.25 will bolt in when most Dana 44's won't plus it will cost a lot more. The 8.25 has a lot more aftermarket support now which is nice. I have a 29 spline 8.25.88 XJ - 5" lift - 35" BFG's - Bumpers - Rock Rails - Homebrewed OBA - Roof Rack - Tube Doors - Trimmed - Dented
Originally posted by RuffedUpXJ View Postmost Dana 44's won't...
Pinion's a little longer, but that's all...
RobertDIRTY DEEDS, DONE DIRT CHEAP
Originally posted by WrenchMonkey View PostNot sure what you mean by "most 44s" but I assumed he was talking about an XJ 44, which obviously would bolt in.
Robert88 XJ - 5" lift - 35" BFG's - Bumpers - Rock Rails - Homebrewed OBA - Roof Rack - Tube Doors - Trimmed - Dented
Originally posted by RuffedUpXJ View PostYes thats what I meant Robert, considering $400 is about the going rate for the 87-88sih XJ 44 and you can get a 29 spline C8.25 for $50-&100. Also you could snag a 8.8 with Disc's and a mount kits for around the $400 range or cheaper if you are a shopper.
I've even considered selling my locked and geared 44, doing up a 29spl, and pocketing the difference.
The 44s are over priced anymore. I sure wouldn't buy another.
My first choice Dana 44...They hold their value.Have you called around ??With the the cash for clunkers program you may find one cheap ..
The 29 spline C8.25 will work fine too..
NickJust a 200 dollar cherokee that wouldn't start ..
