I have a 1987 YJ and I am putting a high output 4.0 from a 1992 XJ in it. I have the whole XJ here and I was using the wiring harness from it. It came with a AW4 transmission but I was going to use my TF999 instead. But now I have come across a 32RH for very cheap and I want to know if I can use the trans with the computer and wiring harness out of the XJ. Any help would be greatly appreciated. Thank You
Transmission question for 4.0 conversion
My guess is Yes it will work as long as you get it wired in correctly and what ever T/C you are using will bolt up..
Heres a link that should help with the wiring part...
http://www.transonline.com/transdige...ers/index.html
Good Luck
NickJust a 200 dollar cherokee that wouldn't start ..
Originally posted by JET455 View PostJust run the AW4 and the 231 T-case you will gain the overdrive and better t-case.91 fj 80 on 37 Nitto Muds with a 10k winch. Cage and sliders coming soon.
