I need your help guys. Went out to start my samurai today and she aint starting! Battery tested good. I dont know what else to do?? Any ideas! PLEASE HELP!!My truck broke today to! I'm in school and work.:confused: :confused:
not starting
so, not turning over at all? Does the radio at least come on when you turn the key to start like usual?
sounds like the starter is bad, try hitting it with a hammer while trying to start it. that may get you home or to somewhere better to work on it.
Not enough info to help you. (Of course, if you swap enough parts, you'll get to it eventually.) Like others have suggested, use a test light and/or a multimeter to see whether you're getting power/ground to the switch, relay, starter, etc. Let us know whether the radio, horn, interior lights work etc.
Good luck.
I've had the same type of issue just because a battery cable was slightly loose and then corroded. Had to pull the cables off, clean everything, and put it back together. When I say loose, it's not like you could easily wiggle the cables on the battery but rather you could just barely rotate the clamp.
