Who makes good bump stops that aren't air bumps? All my money is going to support a welfare recipiant so i can't afford the fancy ones
Bump stops
Prothane coil inserts They compress to like 60% of their size. They are progressive stops. When I was reading about them someone said they are like landing on a cloud of titties. Thats all I needed to hear to try them. I picked up a rod of 1.25 plastic to put inside them for a solid stop if they ever stuff enough to damage stuff. If you get some I still have a couple feet of that plastic rod I could cut you a couple pieces. http://www.amazon.com/Prothane-19-17.../dp/B00387A83G
Originally posted by OH-cj5 View Postdaystar bumpstops.
Originally posted by timido View PostProthane coil inserts They compress to like 60% of their size. They are progressive stops. When I was reading about them someone said they are like landing on a cloud of titties. Thats all I needed to hear to try them. I picked up a rod of 1.25 plastic to put inside them for a solid stop if they ever stuff enough to damage stuff. If you get some I still have a couple feet of that plastic rod I could cut you a couple pieces. http://www.amazon.com/Prothane-19-17.../dp/B00387A83G
Originally posted by Nuts View PostWhere can I get just the polyurethane inserts?
Bump rebuild kit
Stinger with everything is $110
Full bump stop
I'm not at all a fan of the "use your shock as a bump" bull-ony...brad
sigpic
