Wiring the buggy...
  • Wiring the buggy...
    This is what I came up for the battery/charging system. What do you all think?
    LIKE IT OR LEAVE IT!!!
    there will also be a 150 amp circuit breaker between the battery and master disconnect.
      I would probably change the hot wire to the alternator to the other side of the "master disconnect"... otherwise it will be misnamed...
      sigpic
        sorry for the hijack but i have a whole case of gm weatherpack connectorsthat i probly never use that u are more than welcome to if u want them. makes for some clean wiring.
          Oops! Good catch Brad.
          Sending you a pm...
            Rob, your pm box is full!
            • #7
              You want your alternator cable on the battery side like the picture. When you kill power to the buggy you want to kill the ignition and fuel. If the Single wire alternator is on the ignition and fuel side of the switch it will still power run the fuel pump and the ignition.
              • #8
                hey i put alternator wire on other side! lol no but i ran alt. wire to starter power to charge battery to cut down on wires.
                • #9
                  That is the reason I put the alternator on the battery side, thinking it would still run if it was on the opposite side.
                  • #10
                    Wait... what?
                    Maybe I'm thinking about this disconnect differently than most... if I kill the power to the entire rig, then go to pull out the alternator to find it still hot... I would (most likely curse repeatly, and) think that the "Master Disconnect" was misnamed or faulty... This isn't the start/ignition switch, it's a safety/convenience item to kill ALL power...
                    Just my 2 pesos worth, I guess...
                    sigpic
                    • #11
                      Correct. It is to kill all power but if you move the salt wire to the other side like you mentioned, the switch will not kill the engine if it is running because the alternator will be powering everything. Make sense?
                      • #12
                        Are you running a GM Alt? If so, is it a 1 wire or 3 wire?
                        If it is a 3 wire like mine, so long as the volt sense wire is routed to a switched source, you can "turn off" the alternator.
                        • #13
                          or get a single pole double throw style disconect..
                          • #14
                            Its a 3 wire. The switch is a 4 pole type, 2 for battery cable and 2 for alternator field.
                            • #15
                              I guess I never considered this "Master Disconnect" the thing to pull to turn off the engine... dash ignition/fuel switches for that?
                              I just can't wrap my head around the name... sorry, not trying to be a jerk... If this is a kill switch, call it a kill switch... (I would certainly look at it differently at that point) Until the entire rig is de-energized, i have a hard time with "Master Disconnect"
                              ...fun topic though... thanks for starting it up...
                              sigpic
