This is what I came up for the battery/charging system. What do you all think?
Announcement
Collapse
No announcement yet.
Wiring the buggy...
Collapse
X
Originally posted by KargoMaster View PostI would probably change the hot wire to the alternator to the other side of the "master disconnect"... otherwise it will be misnamed...
Originally posted by yellowjacket View Postsorry for the hijack but i have a whole case of gm weatherpack connectorsthat i probly never use that u are more than welcome to if u want them. makes for some clean wiring.Last edited by biggin69; 05-08-2013, 04:58 PM.One Country, One Flag, One Language...
LIKE IT OR LEAVE IT!!!
You want your alternator cable on the battery side like the picture. When you kill power to the buggy you want to kill the ignition and fuel. If the Single wire alternator is on the ignition and fuel side of the switch it will still power run the fuel pump and the ignition.
Wait... what?
Maybe I'm thinking about this disconnect differently than most... if I kill the power to the entire rig, then go to pull out the alternator to find it still hot... I would (most likely curse repeatly, and) think that the "Master Disconnect" was misnamed or faulty... This isn't the start/ignition switch, it's a safety/convenience item to kill ALL power...
Just my 2 pesos worth, I guess...brad
sigpic
Correct. It is to kill all power but if you move the salt wire to the other side like you mentioned, the switch will not kill the engine if it is running because the alternator will be powering everything. Make sense?One Country, One Flag, One Language...
Originally posted by Hope Springs Hauler View PostAre you running a GM Alt? If so, is it a 1 wire or 3 wire?
If it is a 3 wire like mine, so long as the volt sense wire is routed to a switched source, you can "turn off" the alternator.Originally posted by yellowjacket View Postor get a single pole double throw style disconect..One Country, One Flag, One Language...
Originally posted by biggin69 View PostCorrect. It is to kill all power but if you move the salt wire to the other side like you mentioned, the switch will not kill the engine if it is running because the alternator will be powering everything. Make sense?
I just can't wrap my head around the name... sorry, not trying to be a jerk... If this is a kill switch, call it a kill switch... (I would certainly look at it differently at that point) Until the entire rig is de-energized, i have a hard time with "Master Disconnect"
...fun topic though... thanks for starting it up...brad
sigpic
