Since I run an electronic trans I needed to add a vss to the system. Luckily the ford np205 has the same 32 spline output as my np241 had. Drilled and tapped the case for the stock vss, and also had to remove about 1/4" off the reluctor ring width. So for a few hrs work and zero cost I have my oem vss setup.
