Old 04-06-2009, 05:15 PM   #19
winches front and rear and suck it down
Wasn't as worried about the Jeep as other things... (Jeep will have dedicated front and rear axle adjustment) but less worried now... I just measured...
Boat is 6'10" as it sits... *should* be OK
Big Red Truck (which probably won't stay in, but is needed to get the boat/Jeep-trailer from the rear of the garage) is 6'9" as it sits... NEED to keep the conversion to 4wd close to that height, and will most likely have to loose the little rack thing on top.
I know the Jeep trailer is too tall with the ramps up, but I'm wondering about ability to put them up inside the garage...
Originally Posted by maddhatter View Post
Does it even have a header? If it has trusses for the roof making it 8' should be easy.
This was my thought as well. The current owner probably wouldn't have approved pulling drywall to find out about the header though... and I didn't have a ladder with me to get to the access door to see the trusses... So I'll let you know after the inspection later this week.
