lol.ok.it should work though its a remanufactured one rfrom oreily.
#2 | |
Diesel guy
check it with a DVOM. each time you turn the switch up there should be less resistance than the position before. maybe your getting power enough to light a test light but not enough to run the motor.
2013 RZR S |
just hook to motor up to the battery and see if it comes on or not
what do i use to hook the motor up to the battery?
Diesel guy
just use extra wire you might have laying around run one to a positive and one to the negative
2013 RZR S |
ok.ill try that tommorow.i tested to make sure i was getting power to the motor again today and i was so i already called oreily and there getting a new motor wednesday.so ill try that and go from there.thanks for all your help i ll keep you posted.
Make sure its mounted with a good ground from the windshield frame to the body, if not it aint goin work.
