how does the coolant look? Diesel in the oil or coolant? What is the fuel pressure at the injection pump?
The oil was black as night and I changed that today, but it was just oil, and the antifreeze is just that. All the harnesses and plugs seem to be in good condition, and I haven't checked pressure at the pump yet. The way I singled out 6 and 8 was to unplug the plugs that go into the valve cover 1 at a time. When either on the driverside were unplugged, and the front on the pass side there was an obvious change in the idle. When I unplugged the rear plug on the pass side nothing changed. Then when I unhooked each injector (6 or 8) the idle didn't change much, if any at all for either one....so 2 bad injectors, or bad harness????
If it is like my 96, check the condition of the pass through VC gasket. Mine was paired up (1&3, 5&7, etc.) so that if 1 acted up, both would. The signals could be grounding out before they get to the injector. Also, recheck the condition of the under valve cover wiring. With age and miles, the insulation will get very brittle. I lost a few gp's because of that.
woods beater
Is it a miss at idle only or does it stay under throttle? Is your chip running off the shelf tunes or did you get custom tunes burnt for the new injectors? What about the cam position sensor? They are notorious on our trucks for failure, causing a stall or miss. just a thought. Is the fuel filter clean or is it black from oil past the o-rings?
85 toyota ex cab a few goodies |
Its a constant miss, and I replaced the fuel filter yesterday too but it just looked like an old fuel filter.
#6 | |
and I forgot to say before that the truck seems to run smoother/better when it cold. |
