Tony, I cut a small flap out of the floor fromt he top and drilled them out and then took the sway bar connections that go on the spring pad, its shaped liek a "U" and is about 3.5" long and you have to widen it just a bit to get a shoack bushing to go through. So drill them out, attach that piece up there with new bolts, and run normal shocks. Works great a lot easier to change shocks out and I have a lot more options now.
Nate that is what I will do. Can I remove the bar pins and use the same shocks?
Usually as long as you can find a bolt to fit both holes. I forget, I am about to replace mine back there. You may have to widen the bracket or cut down the metal bushing and squeeze the rubber to get it in.
#4 | |
I was wondering the other day if it was still there. I will get them. When?
#6 | |
Or I can drop em off at AHP tomorrow, if that'd be easier. I go right by. See ya
That would be fine with me
