Yeah, i would put on the spacers that come with the kit. And be prepared for the bolts to twist apart or the nuts inside the frame to break free when u loosen them.
or do a sye and longer rear ds., is another alternative.. Think there was one on c/l this month, btw
tommy
didnt buy kit piecing it together just will have to make something
08 jeep Sahara soon to be with 33s |
Try it with out the spacers , I've found that every YJ is different . My old one had a 4" lift and no spacers and it did not vibrate at all . I have installed lifts on several YJ's and TJ's and some have vibrations and need'em and some don't.
www.buckeyejeepers.com
Another option is use a motor mount lift if you happen to have a body lift on. I ran a YJ that way for a while, it eliminates the need to lower the skidplate. I happen to have a used set of 1" lift motormounts for sale that will be going to the Cleves swap meet.
tommy
i will try nothing first and if i have to then i will drop it
I have nothing on my yj with 4 lift but it is a 5speed
