Old 04-17-2011, 08:53 PM   #1
reformed
Too many projects
Alignment. I think its max. toe in and min. caster within the factory specs. Also look for worn out bushings, tie rod ends, wheel bearings. Good luck!
Old 04-17-2011, 09:21 PM   #2
began
began's Avatar
just had the alignment done last week back to spec, bushing all look good and bearings are still good. Scott looked all over them. this thing is killing me..lol
O____O
(O|||||||O)
--O---O--
Old 04-17-2011, 11:50 PM   #3
JasonCJ7
Throttle Jockey
JasonCJ7's Avatar
Does it have a steering stabilizer on it? I had death wobble on mine that started at about 25mph, it was BAD. I balanced my 36" tires and added a steering stabilizer and that took care of the wobble.
Mine is not a DD but I have tested it up 55mph and no wobble.
Just a thought....
Old 04-18-2011, 08:58 AM   #4
jfiscus
jfiscus's Avatar
bumps causing wobble for me have indicated a bad trackbar (if that's what it's called - the bar from the frame to the axle). Those bushings wear out quick & once they're bad the axle can jump all over & scare the crap out of ya. Get a prybar & pry on all your joints in the front end - if any move at all they're bad.
Old 04-18-2011, 09:19 AM   #5
began
began's Avatar
Ive pryed on them and they look okay.....i have a duel steering stabilizer everything looks to be okay... Im going to put the Swampers on it today and see if i just have bad tires or something
O____O
(O|||||||O)
--O---O--
Old 04-18-2011, 10:02 AM   #6
drmeece
drmeece's Avatar
I had the same thing on my Jk....It was caster angle..i had the lower control arms ecentric max out...still dw. torch out the ecentric openning alittle..it helped but still dw...Installed adustable lower control arms set the right caster no problems in two years.
I got a jeep
Old 04-18-2011, 01:33 PM   #7
began
began's Avatar
How long did you set up your lower control arms? and what was your caster angle?
O____O
(O|||||||O)
--O---O--
