#1 | |
![]() I don't know what to suggest then...:(
If it is cross threaded, drill it out and tap it to a larger thread size.
#4 | |
![]() Looks like there is still enough bolt sticking out to weld a nut to. Take that washer off and find a nut that just fits over the existing bolt. Weld the inside of the nut to the bolt. Once it cools, you should be able to remove it with an impact. |
#6 | |
It would be a pain in the ass trying to drill a grade 8 bolt. GET TO IT!!!! ![]()
BYAAH!!! |
I was going to suggest the same thing. With some bolt sticking out after removing the washer it should be pretty easy to weld a nut onto it.
Cross thread good as lock tite!
Its' the time-honored way of making things stay put. If the welded nut doesn't work (please use a new one) then head to the store and get a couple really good bits. Since it is cross-threaded it is locked in tight. I'd tack-weld around the bolt to seal it in then drill out the core. Tap. if it's cross-threaded it likely is not on the correct plane so some of this bolt will be left behind if you are drilling/tapping square to the mating surface. I do not envy your position....but have been there. Last one I did I had a time-crunch, too late to get stuff from the store, and needed to drive to work the next morning. I used up a titanium cutter bit on my dremel carving the guts of the bolt out (horizontal control arm bolt) most of the way then it was weak enough, I drove the fragments out with a punch. There was no way to get even a 90deg drill in the space. Corrosion had welded the bolt to the bushing core which led to the bushing failing and a nice clunk from the control arm. I finished cleaning slivers from the threads with a pick, ran a chaser through it, then put the $20-something-dollars-each factory-shouldered bolts back in. One LONG, frustrating evening. |
