Old 07-21-2012, 05:09 PM   #1
tjrider
Well my thought was..... long arm the front and leaf the rear to eliminate the 4" short arm I have now. I just need it to behave better off-road. I got a HP30 for the front, so I was planning to just get a front radius arm kit and do something different in the back
Old 07-21-2012, 05:11 PM   #2
tjrider
Question; can you run just a front antirock and take the rear sway bar off?
Old 07-21-2012, 05:36 PM   #3
i alway ran just antirock on rear and non in front, so i would think it help out greatly no matter the placement. to me leaf springs are moving backwards performance wise
Old 07-21-2012, 05:44 PM   #4
antirock bar be only a fraction of the $ of a rear leaf conversion...just sayin..
but a couple years ago I read some reviews of a tj rear leaf kit and it was very positive iirc
Ed Zackery my point.
You could probably 4 link the rear for around the same as doing a leaf conversion.
Absolutly! I am pretty sure the make a tj specific kit.
Old 07-21-2012, 05:59 PM   #5
tjrider
The 8.8 is 4 linked already. Just wasn't sure what I wanted to do with the rear short arms. I'd rather build a kit than buy one. I was planning on using used DJ springs then just buy brackets
Old 07-21-2012, 06:06 PM   #6
Sounds like you have it all figured out. You will save some $$$ doing it yourself. Plenty of places offer coil brackets. Hell you could even stretch the rear if you wanted.
Old 07-21-2012, 06:40 PM   #7
underpowered
They call me......Scuba
guy on here, i thin he is Flatlander757 or something like that, has a TJ with 3 link front and uses rear XJ leaves on his TJ. i'd PM him and see what he has to say.
beat up rusted out k5
Old 07-21-2012, 07:18 PM   #8
yeah instead of link suspension , id go leaves and revolver shackles, that b badass getup!
