Question; can you run just a front antirock and take the rear sway bar off?
i alway ran just antirock on rear and non in front, so i would think it help out greatly no matter the placement. to me leaf springs are moving backwards performance wise
SMITH BUILT PERIOD |
#3 | |||
![]() Quote:
The 8.8 is 4 linked already. Just wasn't sure what I wanted to do with the rear short arms. I'd rather build a kit than buy one. I was planning on using used DJ springs then just buy brackets
Sounds like you have it all figured out. You will save some $$$ doing it yourself. Plenty of places offer coil brackets. Hell you could even stretch the rear if you wanted.
They call me......Scuba
guy on here, i thin he is Flatlander757 or something like that, has a TJ with 3 link front and uses rear XJ leaves on his TJ. i'd PM him and see what he has to say.
beat up rusted out k5 |
yeah instead of link suspension , id go leaves and revolver shackles, that b badass getup!
Fartface extrordinair
I did it with Old Man Emu XJ leaves.
http://www.pirate4x4.com/forum/showthread.php?t=768019 If you decide to do it, but good leaves from the start. It rides so much better with these leaves it's silly. Flexes plenty well too. That said, if you can swing it then go 4-link with coils and shocks w/ an anti-roll bar. My Jeep will be getting torn down some time in the near future to cut the tub in half and redo everything basically. Downsizing to 37s or 38s, Toyota Landcruiser axles, trying to drop it down to around 3000lbs, etc etc. I'm going to be 4 linking the rear, probably another 3-link up front this time too though but with coilovers hopefully at all 4 corners but we'll see.... Point being if you plan on doing this, I may have my entire setup for you to buy off of me, bumper, leaves and all. ![]() ![]() ![]() This is the closest to a sidehill pic I've got: ![]() Roughly 12" of stretch, here's a pic to get an idea of the overhang in the rear. With the new leaves it's a bit of a better angle though(replaced because my bastards packs blew ass). ![]() |
So are you for or against? You've said both s:confused:ides.....
