- Moderator - |
I'm ready to see it in action at Harlan in a couple weeks. .. it just can't get here quick enough.
#2 | |
- Administrator - |
Also plated, gusseted, and welded my spring hangers on so I don't tear one off like I did in Lions den last year. The hanger after Lions den and a trail fix so I could keep going. The back is plated and has gussets to the frame. I'm ready for Lions den again. ![]() |
Kevin, lookin awesome buddy!....I dont mind my boggers at all, other than i wish they were a little bigger. Youre going to love that setup.....Did u get them from GoForth?
Im going to try Lions Den this year for the first time ![]()
Good, cause it looks pretty bad!
- Administrator - |
It already looks better. Most of that extra wire is gone. The hard part will be getting the computer to the passenger side inside the cab. The PCM was originally right next to the drivers wheel well. It will be in good shape by the end of tomorrow.
Kudos, on building your own harness from stock! I made mine for the LT1 swap and had to do the same thing with moving the computer from the driver's front to the passenger rear of the engine compartment. By building my own I learned so much more about how the fuel injection system actually worked.
- Administrator - |
- Administrator - |
Dropped the PCM off to a guy in White Oak that will remove all the BS I don't need for $90.. http://lt1pcmtuning.com/ We'll see how he does.
Ordered the fuse block for the engine today. Should work out good. http://www.waytekwire.com/item/46345...RO-RELAY-RTMR/ There is no way I will have this ready for memorial day at Harlan. ![]() |
They call me......Scuba
04 was during the years GM used Castech heads, which are known for hairline cracks in them.
beat up rusted out k5 |
#13 |
- Administrator - |
I checked the heads for cracks and didn't see any. I did this as a preliminary check in hopes of seeing something obvious. Since I didn't, off they go to the machine shop to be cleaned, pressure tested, and checked for flatness. I'm taking them tomorrow to Performance Engineering in Hamilton. I've heard good things about them. https://www.facebook.com/PerformanceEngineeringLLC
