#13 |
Yep, still has sporadic miss and down on power. I rigged up a fuel pressure gauge to check supply to the HPOP and everything was as good as new. I did find a IPR sensor leaking oil pretty bad which will supposedly make the computer controlled trucks have very irratic injector operation, It needs to be replaced and maybe it will also fix the problem.
