Been looking at heims, and link kits. Some kits had larger lowers than uppers, some were the same size. Are 1 1/4 heims with 2" 1/4 wall tubes good for my lowers? Same for the uppers, or smaller. Buy the brackets or make them? I have a plasma cutter...
I thought the shocks were expensive, the heims are ridiculous. About a grand for 16 1 1/4 heims. ![]() |
They call me......Scuba
1 1/4 is overkill for the lowers. granted, overkill is good, but 7/8" are fine. Most guys i know only run 7/8" without issue and is all i am running. Unless you beat it like a bouncer, you don't "need" 1 1/4 heims. especially on the uppers, they see far less stress than the lower do.
as for the tube, once again, overkill is not a bad thing and strength greatly depends on your over all length of the links themselves. a longer link will need a stronger material to better resist bending.
beat up rusted out k5 |
#9 | |
Actually I am on one tons and 38.5's currently, it will be placed everywhere Kevin plans on taking his in Harlan, the badlands etc.. I understand the compromise, but as i said, it is not just me. A few guys i know (not on here) run nothing more than good 7/8" heims on their full size rigs. If you think you need 1 1/4, then by all means get them but i am just saying they are most likely overkill. It is a lot of personal preference i guess. I'd have no concern with 2" 1/4 wall and 7/8" heims in that spot of your pic. Only time i have ever seen a 7/8" break is in a hard roll with lots of side load on them, but i've seen plenty of 1 1/4" break in that same situation as well.
#10 | ||
I bet you could split the difference, though. 2 or 2.25 by 375 lowers on a 1.25 end, then smaller/lighter/cheaper uppers.
