Old 08-26-2018, 09:03 PM   #1
Made some progress on the build this weekend. Still debating on how to do the front.Click image for larger version
ID:	9986Click image for larger version
ID:	9987Click image for larger version
Old 08-27-2018, 12:51 AM   #2
Ooo, I like that profile a lot...
Old 08-27-2018, 11:21 AM   #3
Awesome Kevin!
Are you expecting to remove/rework any of the cab floor to keep a relatively flat belly?
Old 08-27-2018, 11:54 AM   #4
Awesome Kevin!
The main reason I ditched the S10 frame was to duplicate the full size frame so I could keep the belly flat. The area under the S10 is really close to the full size so I shouldn't have to do anything to the floor pan. How it actually works out is another thing.
Old 08-27-2018, 12:36 PM   #5
I always liked the old rig better when it had the fenders on it, so I'm thinking about leaving them on this time. The S10 is a little wider in the front than the big rig was. I think visibility out the front is a lot better in the S10, so do I dove the front or leave it straight. I originally wanted to do all tube in the front, but I don't think it would look right. The fenders will need to be cut along the silver/teal line so there won't be much fender left. The factory grill will be cut to remove the headlights. Since the radiator will be behind the cab, the approach angle should be good.
Old 08-27-2018, 02:22 PM   #6
My opinion is a rig looks a little better if has at least a little bit of the body left to determine what it at least started out as.
In your case it's close to what it truly is..just gonna be on steroids.
Old 08-27-2018, 04:23 PM   #7
I agree!
But you should take my opinion lightly, i still wheel a toyota at heart
