Old 12-12-2007, 09:01 AM   #1
JeepHD
www.buckeyejeepers.com
JeepHD's Avatar
Pics of tires
Trying to get an idea on tire size. Pictured are 36x12.5x16.5 hummer tires and 37x12.50x16.5 Iroks that were borrowed from friend
TSLs arrived
1994 YJ, 4.0, 5 speed.
Old 12-12-2007, 09:05 AM   #2
JeepHD
JeepHD's Avatar
Stak Transfer case and NV3550
Pics of the 2 speed Stak Transfer case. Transfer case was ordered with:
- Drivers side drop
- 4.3:1 gears
- 1350 front yoke
- 1350 rear flange
- Vehicle Speed Sensor
- Pinion brake
www.stak4x4.com
NV3550 that was rebuilt a couple years ago, but has less than 100 miles on it.
Stak Test fitted to NV3550
Out of curiosity I weighed these. Stak weighed in at 130 lbs, NV3550 with bellhousing weighed in at 105 lbs.
Name:  Stak & NV3550.JPG
Transmission and Stak are installed except for the shifters for the Stak. Everything went fairly well after I figured out how I wanted it clocked. Case is big and has eliminated my plans to run a flat skid for now.
Stak came in missing the calipers for the pinion brake, so I need to call on that today
Installed Stak
Name:  Stak Rear 1.JPG
Name:  Stak Rear 2.JPG
Name:  Stak shifter.JPG
Name:  Stak shifter 2.JPG
Old 12-12-2007, 09:19 AM   #3
JeepHD
JeepHD's Avatar
Front Axle
High Pinon Dana 44 (HPD44) front out of a 1978-1979 Ford F-250.
Stock factory perches are used, but I ground hole for spring pin about a 1/2 inch toward center on both sides.
Specs an Parts Used:
OX locker
4.10 gears
Chromoly shafts & Superjoints from Yukon Gear - www.machinewave.com
New Spicer ball joints - www.shakerbuilt.com
High steer - www.kozoffroad.com
1 ton TREs - www.kozoffroad.com
DOM tubing for tie rod and drag link
1350 Yoke - http://www.highangledriveline.com/
U-bolts used - (3) 5/8 x 2 3/4 x 10 (1) 5/8 x 3 1/4 x 10 - www.ruffstuffspecialties.com
u-bolt plates - www.ruffstuffspecialties.com
Name:  Front axle OX.JPG
I need to grind part of the perch to fit ubolts on correctly as you can see in pics. It is just mocked up and u-bolts just finger tight.
Added a couple more pics 2/17/08
Old 12-12-2007, 10:10 AM   #4
JeepHD
JeepHD's Avatar
Rear Axle
D60 out of a 1978-1979 Ford F-250 or F-350
This was a pretty easy swap. Stock perches need to be ground off and new ones welded on to fit Jeep application. Pinion angle needs to be set according to angle of transfer case and type of driveshaft running.
Parts Used:
U-bolts - (4) 5/8 x 3 1/4 x 10 www.ruffstuffspecialties.com
U-bolt plates - www.ruffstuffspecialties.com
Spring Perches - www.ruffstuffspecialties.com
Disc brake brackets - www.greatlakeoffrad.com
1350 Yoke - www.shakerbuilt.com
Disc brakes - 1975 Chevy 3/4 ton calipers and rotors
New Seals
Old 12-12-2007, 10:14 AM   #5
JeepHD
JeepHD's Avatar
Suspension
With the axle swap I am converting to a Spring Over Axle (SOA) setup.
Rear - I used two main leafs from a superlift 1.5" replacement spring pack with the smaller leafs from the stock springs
Name:  Front Spring.JPG
Front - I used stock YJ packs but I took a main leaf from another pack and cut the eyes off and added it below the main leaf
Name:  Rear Sring.JPG
Old 12-12-2007, 10:14 AM   #6
JeepHD
JeepHD's Avatar
Steering
Few pics of the Hi-Steer so far.
Old 12-12-2007, 10:15 AM   #7
JeepHD
JeepHD's Avatar
Tire and Rim Information / TJ flare conversion
I will be running 38 x 12.50 x 16.5 TSLs on H1 8 bolt hummer rims 8.25 x 16.5
35 lbs - H1 rim only(no beadlock or runflat)
47 lbs - H1 rim with complete runflat
41 lbs - H1 rim with beadlock (runflat cut off)
12 lbs - Runflat
6 lbs - Beadlock only (runflat portion cut off)
73 lbs - TSL only
114 lbs - Tire, rim & beadlock
456 lbs - (4) tires and rims
H1 Info thread - http://www.cincyoffroad.com/forum/showthread.php?t=1329
Tire Choice thread - http://www.cincyoffroad.com/forum/showthread.php?t=1293
Another Tire Choice thread - http://www.cincyoffroad.com/forum/showthread.php?t=1256
