Old 12-16-2007, 03:07 AM   #1
looks good...
slider and frame tie in = a bunch o work.
Old 12-16-2007, 06:37 AM   #2
Looks good Mike ,
you going to do anything about that Rock Tattoo / soup bowl in the rocker ?
Old 12-16-2007, 07:00 AM   #3
Looks great Mike!
Old 12-16-2007, 09:00 AM   #4
Those rocker/ cage tie ins are sweet.
Old 12-16-2007, 09:08 AM   #5
Looks good Mike ,
there's one on each side... he dropped it down onto a rock ledge, first run out after the new paint...
covering them up with 3/16 or 1/4 rocker plates...
Old 12-16-2007, 09:38 AM   #6
Very nice work! When can we see this copper beast wheel?
Old 12-16-2007, 09:49 AM   #7
eighty3bronco
anywhere but there
eighty3bronco's Avatar
I love that hammer finish on the sliders, stinger and rear bumper!!!
Old 12-16-2007, 02:21 PM   #8
Coby
Coby's Avatar
vedday nice! High-5. I need to come down and check it out. Whats the word on his motor?
Coby is offline   Reply With Quote
Old 12-16-2007, 03:35 PM   #9
BiggDaddy
BiggDaddy's Avatar
Rear Bumper
What's with the plating and bolts on the back side of the rear bumper? Are you going to bolt it on? I'm in the process of making very similar bumpers out of the same stuff. Really thick rectangular tubing.
BiggDaddy
Old 12-16-2007, 07:20 PM   #10
motor is done and ready to be put back in...
for those of you that don't know, its a ridiculously built small block 400... very strong...
Old 12-16-2007, 07:19 PM   #11
This year i'm sure... he will probably do quite a few trips.
Old 12-16-2007, 09:07 AM   #12
looks good...
yes, takes a while to get it all lined up and correct, then gotta pull it all out and weld it all up, hoping that it all the tacks hold in the pullout... then hope that in welding it all up, it didn't tweak from the heat... ugh.
Yes a lot of work, but very rewarding with how they turned out.
I will call you tomorrow Rob about cutter my rocker plates... i have my needed measurments.
