Old 01-17-2019, 01:26 PM   #126
I need to make new driveshafts, so I need yokes and tubing. What is the OD and wall thickness of what you're using? I need to know what's holding up to the abuse we put them through. The last ones I built I used the 2 1/8 DOM I had laying around. I want to use something more common this time.
I also need to know how much slip to use on a linked suspension. I know it won't move as much as it did with the leaf springs. Knowing the diameter of the spline would help too.
I guess no one has driveshafts...
Old 01-17-2019, 01:41 PM   #127
I do but I have a yoda..
I run 1/4 wall Dom.
Don't remember diameter right off,
Would have to measure.
I wouldn't make anything less than 1/4 wall.
I bent or twisted anything less.
Old 01-17-2019, 02:56 PM   #128
I run .1875" wall tube. 14" of slip is good. Too heavy can eat up parts. Best weak link is driveshafts.
Old 01-17-2019, 03:21 PM   #129
I told you what my measurements were. Guessing you need a whole driveshaft?
Old 01-19-2019, 11:30 AM   #130
Tom woods uses 2" .120 wall for driveshafts.
Old 01-19-2019, 11:40 AM   #131
I used 2", 1/4 wall DOM. Ordered my yolks from Northern Drivetrain and Carolina Driveline machined to fit. Made them in the buggy.
Old 01-23-2019, 05:41 PM   #132
I ended up buying parts for 2 in quarter wall tubing. Has about seven and a half inches of total slip. This should be plenty strong.
Old 01-31-2019, 07:27 PM   #133
Been working on getting the tcase tucked in and making a sturdy crossmember. My last one was bent up, so I beefed this up. Had to cut a big hole in the floor to get the tcase up where i wanted it. Still sticks out the bottom an inch. So much for a flat belly pan. Oh well, it will be mostly flat...
Old 02-05-2019, 09:17 PM   #134
Got my t case shifters mounted in my console. Worked out perfectly by cutting out the square junk tray.
Old 02-06-2019, 06:26 PM   #135
Man that turned out great!
Old 02-18-2019, 08:25 PM   #136
Since I run an electronic trans I needed to add a vss to the system. Luckily the ford np205 has the same 32 spline output as my np241 had. Drilled and tapped the case for the stock vss, and also had to remove about 1/4" off the reluctor ring width. So for a few hrs work and zero cost I have my oem vss setup.
Old 02-21-2019, 08:46 AM   #137
Got the front end back on. Now i can build the frame from the firewall to the core support.
Old 02-21-2019, 11:21 AM   #138
Lookin good, almost there man!
Old 02-21-2019, 12:12 PM   #139
Ky Mudhunter
Ky Mudhunter's Avatar
I did the same thing on my Ford 205 for the speed sensor. I couldn't believe how easy it was to add.
Old 02-21-2019, 02:17 PM   #140
Looking good, when are the axles going under it ?
Old 02-21-2019, 02:18 PM   #141
Old 02-21-2019, 08:06 PM   #142
Not soon enough. I'll most likely get the engine wired up before the axles go in.
Old 03-11-2019, 12:08 PM   #143
Any update?
Old 03-12-2019, 08:44 PM   #144
I missed a week working on it cuz i was sick.
I got the pcm and fuse block mounted, frame and motor mounts done. Winch is ready to mount, and core support cut down to mount on frame.
Old 03-24-2019, 07:56 PM   #145
Welded up the trusses, link brackets and set them in place today with Kevin. Gonna be really sweet when done. Click image for larger version
ID:	10331Click image for larger version
ID:	10332Click image for larger version
ID:	10333Click image for larger version
Old 03-26-2019, 10:58 PM   #146
That was a big help, thanks. Like 4 hrs of welding. Finally got the axles under the rig. Got the front and rear truss installed. The front and rear 4 links are almost done.
My last trip to Harlan i lost my pinion bearing. I was sure the gears were destroyed, but luckily there wasn't much damage to the teeth.
Old 04-03-2019, 12:41 PM   #147
Working on the shocks now.
Old 05-09-2019, 04:22 PM   #148
Back is done except the aluminum panel for my turn signals and reverse lights.
ID:	10377Click image for larger version
Old 05-10-2019, 09:39 AM   #149
Looking awesome! Let me know when you want that aluminum
Old 05-14-2019, 11:46 AM   #150
Thanks, will do. Tim has a piece of stainless I might use instead. Depends on how it looks.
