Old 10-08-2007, 04:08 PM   #1
84cj-7-3/4
Guest
Posts: n/a
axle swap
i have a 84 cj-7 i'm installing a set of 1982 3/4 ton chevy axles, whats some of the things i need to do to properly do this swap? thanks 84cj-7-3/4
Old 10-08-2007, 04:12 PM   #2
JET455
JET455's Avatar
You need to outboard your front spring hangers to match the chevys width. There are kits out there for this by poison spyder etc.. or do your own. And on the rear you can just change the spring perches to match the rear springs.
Old 10-08-2007, 04:45 PM   #3
84cj-7-3/4
Guest
Posts: n/a
axle swap
thanks i did make my own for the front and i'm now working on the rear, just wasn't sure if thats all that needed to be done. I'm also droppin in a 327 and a 700r4 trans will the stock leave springs hold up. It had a 4 cyclinder when i first got it.
Old 10-08-2007, 04:58 PM   #4
scarface
I beat anorexia!
scarface's Avatar
might as well stretch the wb while your doin all that work
Old 10-08-2007, 06:11 PM   #5
Are you going to have plenty of gearing with the auto and larger tire setup?
