Old 08-22-2008, 04:23 PM   #1
steve
Guest
Posts: n/a
shift motor
i have the old vacuum set up i was going to change it to posi-lock but where the cable goes in there is a senor can i pull that senor out and run the cable through that or do i need a new shift motor ?
Old 08-23-2008, 09:27 AM   #2
The posi-loc replaces the vaccum motor on the axle. You dont have to get a new one because it comes with the posi-loc.
Old 08-25-2008, 08:12 AM   #3
Are you locked in the front? I assume you're talking about a D30 axle, probably on an XJ or YJ. If you're not locked, do it this way & you wont have to mess with it again.
