Old 08-24-2009, 12:50 AM   #1
bc35339
bc35339's Avatar
my new ride
I picked this up sat. and was able to take it to the trails for about 2 hours today.
Old 08-24-2009, 06:00 AM   #2
drmeece
drmeece's Avatar
And promptly put it on it's side.....Got to like that!!!!
I got a jeep
Old 08-24-2009, 08:07 AM   #3
Nice ! details on the buggy ???
Old 08-24-2009, 08:10 AM   #4
x2
Old 08-24-2009, 08:54 AM   #5
Looks like you swapped pane tanks just before the roll, ha.
give us some specs on the rig.
Old 08-24-2009, 09:29 AM   #6
bc35339
bc35339's Avatar
[QUOTE=carwash;26856](Looks like you swapped pane tanks just before the roll, ha.)
(give us some specs on the rig.)
Good eye! That was the first time to swap tanks on the buggy and I had a heck of a time doing it wasent in the best place to be swaping tanks. The tanks that came with the buggy are the steel forklift tanks and are a big differance on weight compared to the alum. 10 gallon tanks I use on my toyota truck. I plan to let the steel ones go with the truck and keep the bigger alum. for the buggy if they will fit. I havent tried it yet.
Heres the list the seller give to me.
•TOYOTA MOTOR
•RUNS ON PROPANE
•TWO PROPANE TANKS
•TOYOTA 5 SPD TRANNY
•MARLIN CRAWLER DUAL CASE ADAPTER
•CHEVY 10 BOLT FRONT AXLE
•CHEVY 12 BOLT REAR AXLE
•LOCKED FRONT AND REAR
•CHROMOLLY SHAFTS FRONT AND REAR
•BEADLOCKS (I THINK THEY ARE MRT)
•42 INCH IROKS TONS OF TREAD
•DISC BRAKES FRONT AND REAR
•STAINLESS STEEL BRAKE LINES
•FULL HYDRAULIC STEERING
•WILWOOD HYDRAULIC CLUTCH
•RACING BUCKET SEATS
•5 POINT HARNESSES
:OPTIMA BATTERY
:REAR SWAYBAR
:2,000 LBS
IT'S 4 LINKED FRONT AND REAR, HEIM JOINTS ALL THE WAY AROUND, AND HAS 18 INCH LONG TRAVEL AIR SHOCKS.
THE WINCH IS A RAMSEY 8,000 LBS
WIRED IN THE CAB CONTROLS.
Something he forgot to tell me is that it has the worse oil leak ive ever seen. Looks like its leaking somewhere around the timing cover I plan to fix it this week
Old 08-24-2009, 09:35 AM   #7
Old 08-24-2009, 11:23 AM   #8
i beleive this to be same said rig and its no stranger to gravity
Old 08-24-2009, 01:04 PM   #9
staged shot or flat ground roll?
Old 08-24-2009, 02:08 PM   #10
heres the moment right before gravity took over. thats the empty foundation at the badlands
Old 08-24-2009, 02:23 PM   #11
so he tried to roll it... no way he thought he was somehow gonna climb it...
Old 08-24-2009, 02:32 PM   #12
i didnt say he was the sharpest crayon in the box
Old 08-24-2009, 03:38 PM   #13
I would have never tried that.
Old 08-24-2009, 04:06 PM   #14
So you did that too?
Old 08-24-2009, 04:13 PM   #15
No, Sally just takes his rigs "swimming."
Nice looking rig.
Old 08-24-2009, 05:32 PM   #16
boomhauer
boomhauer's Avatar
i remember swimming one year at windrock there brad. people who live in glass houses....
Old 08-24-2009, 07:10 PM   #17
uh oh does brad have a story he would like to tell
Old 08-24-2009, 09:53 PM   #18
bc35339
bc35339's Avatar
2 days after pickup.
Pulled motor to replace throw out bearing and found out that the inputshaft had about a1 inch of front to back play and 1/2 inch up and down play so I replaced it with another w56 and I have a centerforce clutch and pressure plate for it.. For the oil leak the timing chain cover is cracked ( the bolt that goes through the valve cover was tightened to much and cracked the cover so Iam replacing that and puting a new head gasket on while its apart. Was going to put a cam in it but looks to have a new aftermarket cam in it of some kind.
Old 08-24-2009, 10:34 PM   #19
good looking buggy, but damn, a 10 bolt and 42's? those axles have to already be living on borrowed times.
Old 08-24-2009, 11:30 PM   #20
I drug a trans and T-case to zooki melt because the previous owners buddy said this buggy needed them. But once I got there they told me he had bought a complete truck and didn't need mine anymore:mad: sounds like he needed them after all...
It is a nice rig though
Old 08-25-2009, 07:39 AM   #21
bc35339
bc35339's Avatar
He told me that it was just a throw out bearing making the noise.
O well ill have i lined out in a week or so
I plan on putting new skins on it to.Ill take some pics as I go and post them.
Question?
I bought this off ebay and asked seller about any knowed problems and he said nothing about the oil leak that leaks about that size of the bottom of a 5 gallon bucket in 2 min. of running.
What kind of feedback should I leave???
Ive been holding off on doing this not sure on to say anything about it?
Old 08-25-2009, 08:48 AM   #22
Question?
Ask him about the leak once more and see what he says. I would go negative it sounds like on the feedback unless he is willing to work something out. .02 cents worth right there!
Old 08-25-2009, 09:01 AM   #23
Maybe the known problems should have included that the driveline was f'ed
Old 08-25-2009, 09:11 AM   #24
Negative feedback doesn't mean **** to most people. If you want to do something about it, make him pay for the repairs to it. Or if you payed thru paypal, file a grievance with them for partial money back. Or tell him you are going to file a grievance if he doesn't cover the cost of the cover and materials, etc.
Old 08-25-2009, 09:26 AM   #25
you bought at the risk of not looking at it beforehand.
and you picked it up at some point, am sure you gave it a once over
the five gallon oil leak might have been noticable?
fix it and move on with your life
My vote is you leave no feedback,
