Old 08-30-2011, 03:10 PM   #1
HumminNBoatin
Like Nothing Else
HumminNBoatin's Avatar
Need a piece of pipe ripped
I have a piece of 4" schedule 40 pipe that I need ripped in half. It is 9 ft. long. Does anyone know of a place where I can have this done?
The Hummer Club Inc.
Director - Events Planning/Ambassador Program
Eric@TheHummerClubInc.com
www.thehummerclubinc.com
HumminNBoatin is offline   Reply With Quote
Old 08-30-2011, 03:37 PM   #2
Schedule 40 plastic or metal pipe?
Old 08-30-2011, 08:35 PM   #3
For what someone will charge you to do this, you could damn near buy yourself a metal cutting circular saw and do it yourself.
If you have a buddy with a plasma, put a straightedge on there and cut it up. Or any metal shop should be able to help you... Spring Grove Sheet Metal maybe?
Old 08-30-2011, 09:01 PM   #4
How perfect does it need to be? I can do it at work(on 741 in mason) but it won't be to machinist specs.
Old 08-30-2011, 09:17 PM   #5
HumminNBoatin
Like Nothing Else
It does not need to be to machinist specs. This piece of pipe is 9 ft. long I do need it pretty straight. What I need is someone with a big ban saw. Nuts this help would be GREATLY appreicated! How do I get ahold of you to get this cut?
Old 08-30-2011, 11:28 PM   #6
I have a tubing cutter that should do it.
Old 08-31-2011, 07:54 AM   #7
Do you mean cut down the middle, as in turning the pipe into 2 long "C" shaped pieces?
FYI - I've seen some people try this with smaller tubing and it always curled up some (did not stay flat). Not sure if the schedule 40 would do that or not.
Old 08-31-2011, 09:00 AM   #8
HumminNBoatin
Like Nothing Else
Yes I am looking to have 2 long "C" shaped channels. It should not curl up. I am assuming this is schedule 40. Its 4 1/2" OD, 4" ID and 1/4"Wall. I am making rock rails for the HUMMER.
I have a PM into NUTS to take him up on his offer but have not heard back yet.
Old 08-31-2011, 09:26 AM   #9
Its gonna look like a banana, but would be easy enuf to straighten back out
Old 08-31-2011, 02:44 PM   #10
HumminNBoatin
Like Nothing Else
I found a laser cutter and dropped it off.
Old 08-31-2011, 03:31 PM   #11
I'll be curious to see how it turns out as I considered using this method for body protection on my rig (half of a tube/pipe welded along the body seams).
Old 08-31-2011, 04:51 PM   #12
HumminNBoatin
Like Nothing Else
It turns out well. What I am doing is nothing new in the HUMMER world. According to most H1 owners its the "first thing" you do to an H1 if you are going to offroad it. Looks like this.
Old 09-01-2011, 10:02 AM   #13
so you got this done then ? i know rubberduck has a set up to do it if you still need it.
Old 09-01-2011, 02:23 PM   #14
HumminNBoatin
Like Nothing Else
Very funny Scotty lol.
