Old 12-14-2011, 05:52 AM   #1
hotrod
Diesel guy
hotrod's Avatar
yj axle codes
So I just bought a rig with yj axles under it and I'm not sure what gears it has. I've worn out Google trying to find axle codes but all I seem to be coming up with is lists of what axles came under what Jeeps, not the gear ratios. Even tho its not a hard job, I really don't want to pull a cover and count if I don't have to. Any body have any clue what codes mean what? I think I found that 46-15 is a 3.07 and 46-13 is a 3.54. But what about 3.73 and 4.10? ( I tried searching 46-11 46-09 etc no luck):o
2013 RZR S
Old 12-14-2011, 06:42 AM   #2
simple take the big number and divid by smaller number gives you the gear ratio..
46-11= 46/11= 4.18
46-09 = 46/9 = 5.11
Old 12-14-2011, 07:09 AM   #3
Count and divide, or just turn the wheel and count number of times the pinion turns... that can get you close.
Old 12-14-2011, 07:58 AM   #4
Is it a 4 or 6 cyl, auto or 5 speed?
Old 12-14-2011, 09:40 AM   #5
hotrod
Diesel guy
hotrod's Avatar
46-11= 46/11= 4.18
46-09 = 46/9 = 5.11
who knew... i feel like an idiot for not connecting those dots haha
true dat
i think the axles came out of a 6 cyl manual. i was told either 3.55 or 3.75 but most likely 3.73
biggest thing is the rear is locked so im looking to get an 8.8 from an exploder and get the correct gears off the bat with a limited slip insted of my current lincoln locker the pops, snaps and chirps my tires :mad:
2013 RZR S
