Old 04-10-2012, 09:29 AM   #1
toyotatodd
Arrow Toyota trannys
I have a 5 speed with transfer case out of a 88 an have a 86 automatic with transfer case $250 also have a 22re needs rings and a front seal $100. I'm located in Winchester, ky you can call or txt 859-749-5595
toyotatodd is offline   Reply With Quote
Old 04-10-2012, 09:32 AM   #2
toyotatodd
5 speed has new clutch transfer case works good still in truck
Old 04-11-2012, 09:12 AM   #3
simpletoy
Cases top shift or forward shift?
Old 04-25-2012, 05:44 AM   #4
toyotatodd
What is the difference in top shift and forward shift?
Old 04-25-2012, 09:09 AM   #5
simpletoy
No need for one now but top shift the shifter is actually on top of the transfer case forward shift the shift forks go into the transmission and the shifter bolts to the top of the trans
Old 04-25-2012, 10:16 AM   #6
toyotatodd
Ok. Thanks for looking and answering my question
Old 05-01-2012, 10:03 PM   #7
toyotatodd
Motor is getting scrapped this week. The w-56 and the automatic I still have. The w-56 has a top shift not sure about the automatic
Old 05-07-2012, 11:17 PM   #8
cheapthrills49
VANILLA GORILLA
cheapthrills49's Avatar
The auto t-case is chain driven and they arnt worth there weight n scrap.....
If your junkin this weekend i'd throw that t-case on the pile but keep the trany. The trans "body" is the same as a jeep AW4 and several others.......Nissan, Mazda, Mitsubishi Toyota, and you can even find a 60* Chevy bellhousing off of some Isuzu V6 trucks that will fit that trans body.
Then AW4 tail housing and your ready for a bolt on D300 or atlas without an adapter.
The actual trans is an Asian design and since jeep sucks they couldn't build an auto to hold up, they had there co. (Warner) build a bell housing and tail housing to fit the Asian trans a bought a few million......thats how jeeps keep goin...Asian trans! A(asian)W(warner)4(speed)
Toyota's call out is A340 H or F
Old 05-08-2012, 05:41 AM   #9
toyotatodd
Thank you cheapthrills49 for the info
Old 05-16-2012, 06:33 PM   #10
toyotatodd
Motor has been scraped bit do have the automatic transmission/t-case and the w56 with top shift transfer case has a new clutch $200 a piece located in Winchester ky call or txt 859-749-5595 or pm me
