Student Driver
Bump StopS how to
I got my tank and am back to setting up my 4 link. With Poly 4 link brackets the lower has a little triangulation. That little triangulation puts the lower arm into the frame rail when one side is stuffed and the other is at full droop. Is that when I should set my Bump stops with one wheel stuffed?
#2 | |
S10 with a few air shocks.. ![]() |
Student Driver
4 link rear Upper Triangulated about 25 degrees each side the lowers are triangulated about 15 degrees No track bar. I will try to get some good pictures.
