Originally posted by fabricator
View Post
2000 Dodge Truggy
Originally posted by 94Dodge Truggy View PostAt shop and at home. I should be able to post pics. tonight.
If you need a hand with getting them uploaded let me know.Friendship is like peeing your pants, everyone can see it,
But only you can feel the true warmth.
sounds cool. you plan on tubing it out, exocaging or just full bodied? how close to stock wheelbase are you going to be? your desired width might be hard. butch is at 90-92" with his hubs flipped in with 42's on his (unfortunately 4" narrower than my wide ass pig). his wheels are backspaced just enough for his hub to be just inside the wheel.
gregzuk buggy.....it'll be a jeep eventually.
Originally posted by mckeddie View Postsounds cool. you plan on tubing it out, exocaging or just full bodied? how close to stock wheelbase are you going to be? your desired width might be hard. butch is at 90-92" with his hubs flipped in with 42's on his (unfortunately 4" narrower than my wide ass pig). his wheels are backspaced just enough for his hub to be just inside the wheel.
gregsigpic
Originally posted by cheapthrills49 View Postdon't you have 2 run 20" rims when you flip your hubs, for clearance
my hubs will be flipped, and i am running 16.5" hummer wheels.
stock hummer width, with centers he made. the center of the wheel is 3" front lip of the wheel. i lied, his hubs are flipped out. he backspaced them to where there was about an inch of clearance to the drive flange (width of drive flange will be the same no matter which way you flip the hub, that will be your problem with width i think. he is exactly 7'6" wide or 92" for the mathematically challenged.
where did you get your rockwells? i know of a set for sale that are basically identical to your specs, just wondering if they were the same ones or not.
i forgot to mention, the reason he didn't end up flipping his in, is because of clearance issues with his airshocks. his front tubework was already done from when he had my 60's under it, and he didn't want to have to redo it all to make new upper mounts.zuk buggy.....it'll be a jeep eventually.
