Old 06-16-2010, 12:03 AM   #1
I broke 2 bar pin bolts on one shock in the rear. What is the best way to get those out?
Drill em. If your hands are small, you can snake a nut into the cavity above it. I managed it, but it wasn't easy. I don't think I could get a long enough bolt in from the topside. If you can't sneak either one in there, you'll be drilling a hole in the floor.
Old 06-16-2010, 05:31 AM   #2
I have drilled them out before but we all know how much that brings on the suck !
the best way I have found is quick and easy ... just weld a couple bolts to the frame and make studs . I have done this on several XJ's and TJ's and not had any reported failures .
Old 06-16-2010, 08:22 AM   #3
RuffedUpXJ
RuffedUpXJ's Avatar
Tony, I cut a small flap out of the floor fromt he top and drilled them out and then took the sway bar connections that go on the spring pad, its shaped liek a "U" and is about 3.5" long and you have to widen it just a bit to get a shoack bushing to go through. So drill them out, attach that piece up there with new bolts, and run normal shocks. Works great a lot easier to change shocks out and I have a lot more options now.
Old 06-17-2010, 02:00 PM   #4
Nate that is what I will do. Can I remove the bar pins and use the same shocks?
Old 06-18-2010, 08:24 AM   #5
RuffedUpXJ
RuffedUpXJ's Avatar
Usually as long as you can find a bolt to fit both holes. I forget, I am about to replace mine back there. You may have to widen the bracket or cut down the metal bushing and squeeze the rubber to get it in.
Old 06-19-2010, 01:55 AM   #6
Originally Posted by RuffedUpXJ View Post
Tony, I used the sway bar connections that go on the spring pad...
Nate that is what I will do...
I've still got a pair sitting on my porch, if you want em...
Old 06-19-2010, 02:06 PM   #7
I was wondering the other day if it was still there. I will get them. When?
Old 06-20-2010, 02:07 PM   #8
They're sittin on my trailer now, you can pick em up any time you happen by.
Or I can drop em off at AHP tomorrow, if that'd be easier. I go right by.
See ya
