Old 12-03-2009, 11:40 PM   #1
lky13blazer
lky13blazer's Avatar
tire question
does the width of your wheel affect the height of the tire? i have 2 sets of 35's and theres about 1.5" of differance...one sets on 10" wide wheel the other is on 7 or 8"... and the one on the wider wheel is the ones that are shorter..
lky13blazer is offline   Reply With Quote
Old 12-04-2009, 12:24 AM   #2
Rim width does matter a little, but you'll see more difference from brand to brand.
My 35" BFGs are almost a full inch taller (and an inch narrower) than my old Dunlops...
Are all yours the same make?
Old 12-04-2009, 08:01 AM   #3
Yea, what he said....I'd have said make is more of a height difference than width...
Old 12-04-2009, 08:35 AM   #4
I know my worn BFGs are barely 33.5" tall and they are 35's.
It is more of the brand having differnt heights. Just like TV's they are in a "class" of sizes. So your 50" TV could only be 49.6".
Old 12-04-2009, 09:40 AM   #5
lky13blazer
one set is the old style buckshot mudders the other set are called bigfoots... do you guys think it would hurt anything to run 2 of the shorter ones on the front and the taller ones on the back,i have a k5 blazer..i also was gonna put the shorter ones on the narrower rims to try to get a little more height
Old 12-04-2009, 10:21 AM   #6
you can try that like you said to get alittle more height to match them and if 4 wheel drive is used on slippery surfaces but if you get on a harder packed surface it will put extra strain on the drivetrain.
Old 12-04-2009, 10:23 AM   #7
An inch difference offroad is tolerable, but as Scott said, keep it in 2wd on the road.
Old 12-04-2009, 10:37 AM   #8
...keep it in 2wd on the road.
Heck, you should keep it outta 4x onroad even if all four match...
Old 12-04-2009, 10:56 AM   #9
lky13blazer
yea i figured out after my last wheelin trip i'm gonna use it for off road only...i was gonna try to do both but i wheel it to hard to do that ..
Old 12-05-2009, 01:13 AM   #10
Eh, break it the first few trips out, then you know what to upgrade.
Eventually, you'll get the bugs and weak links worked out of it.
Then you can drive it to work every day for seven years.
Like me.
Old 01-07-2010, 11:58 PM   #11
mossyoaktj
mossyoaktj's Avatar
Like me.
x2
UNITED STATES MARINE
Old 01-08-2010, 05:54 AM   #12
You could also adjust the height with the air pressure.
Old 01-08-2010, 10:07 AM   #13
lky13blazer
i was kinda thinking that myself.. i'm gonna put them on wed or thurs i guess...i had to buy new lug nuts for the alum rims and i'm have to put tubes in the buckshots cause they don't wanna seal around the rim or they would of been on all ready...
Old 01-15-2010, 04:55 PM   #14
Did the tubes work out for you? I put a tube in a tire and it lasted a day before the tube and tire were shot.
Old 01-15-2010, 05:54 PM   #15
cheapthrills49
VANILLA GORILLA
cheapthrills49's Avatar
i run tubes in mine, im on my 2nd different set of tires and tubes and never had a problem. i buy Firestone hd tractor tubes from the local tractor joint. i like the thought of being able 2 cut a side wall, or hit a nail or some goofy crap like that, and being able 2 just change a 40 dollar tube
Old 01-15-2010, 07:28 PM   #16
lky13blazer
didnt get a chance to put them in yet...will be asap... what went wrong with yours?
