Old 12-27-2009, 03:16 PM   #1
fordman00
fordman00's Avatar
sammi wiper motor.
Hey guys, i have an 88' sammi and the wipers arent working i replaced the wiper motor with a reman. one, didnt work. i need some ideas why this aint working?
thanks,
adam
Old 12-27-2009, 04:17 PM   #2
hotrod
Diesel guy
hotrod's Avatar
Are you getting power to the motor? blown fuse maybe? bad switch?
2013 RZR S
Old 12-27-2009, 05:58 PM   #3
fordman00
fordman00's Avatar
im getting powers to the motor.and good fuses. i dont know how to check the switch though.
Old 12-27-2009, 11:01 PM   #4
smack it with a hammer while turning it off and on.
Old 12-28-2009, 01:43 AM   #5
hotrod
Diesel guy
hotrod's Avatar
and if that doesnt work, get a bigger hammer
2013 RZR S
Old 12-28-2009, 03:15 PM   #6
fordman00
fordman00's Avatar
lol.ok.it should work though its a remanufactured one rfrom oreily.
Old 12-28-2009, 04:12 PM   #7
hotrod
Diesel guy
hotrod's Avatar
your right it should.
check it with a DVOM. each time you turn the switch up there should be less resistance than the position before. maybe your getting power enough to light a test light but not enough to run the motor.
2013 RZR S
Old 12-28-2009, 04:25 PM   #8
just hook to motor up to the battery and see if it comes on or not
Old 12-28-2009, 05:20 PM   #9
fordman00
fordman00's Avatar
what do i use to hook the motor up to the battery?
Old 12-28-2009, 07:07 PM   #10
hotrod
Diesel guy
hotrod's Avatar
just use extra wire you might have laying around run one to a positive and one to the negative
2013 RZR S
Old 12-28-2009, 08:24 PM   #11
fordman00
fordman00's Avatar
ok.ill try that tommorow.i tested to make sure i was getting power to the motor again today and i was so i already called oreily and there getting a new motor wednesday.so ill try that and go from there.thanks for all your help i ll keep you posted.
Old 12-28-2009, 11:34 PM   #12
tinbeater
tinbeater's Avatar
Make sure its mounted with a good ground from the windshield frame to the body, if not it aint goin work.
