i don't think so... if you have any doubts, go get some new bolts, can't cost that much.
Need some help with my YJ
I have always reused the bolts and just put some threadlocker on them.
Pulling the tranny would be much easier than pulling the engine. I just pulled the transfer case and transmission on mine and it took me part of an evening by myself. Get at least two other guys to help put it back in, two underneath and one up top. The hard part is getting the the tranny to slide back in the pilot bushing. Sometimes it slides right in, other times it can be a pain. I would say plan an evening to pull and an evening to reassemble or it can all be done in a weekend day.1994 YJ, 4.0, 5 speed.
Originally posted by 87yjinCincy View PostThe tranny is already out. We only worked on it for 2 hours the first night. We didn't bust our balls on it by any means. We got it out the next day. I've been busy as hell so I haven't been able to get back in there and finish the job. It'll be done this weekend though.
Let's get it out on the trails!
i used to be able to get the engien out of my YJ in a little over 30 minutes, that was a fuel injected 4.0l. we got pretty good at it over the years. not too hard if you mark all the wires before hand as to where they go, and make a list of everything to reconnect as you pull it (had a buddy write it down while we tore it down) then used that as a checklist when reassembling. make sure the bolt holes on the new fly wheel are EXACTLY the same as the one you pull off. we did it one time, and upon reassembly, found out one hole was 1/8" off, the other 3 were right on. took a week before the right one showed up (this was on a 91 auto). good luck. it's pretty straight forward to pull. i'm probably going to start pulling my TJ's sunday.
if it were me, i would try a new starter before replacing that though. looks like the gear on the starter is pretty chewed up, you never know, a new starter could get you by for another year or 2. you are going to have to replace it anyways (lifetime warranty??)
greg
gregzuk buggy.....it'll be a jeep eventually.
