Zach’s buggy build
It’s been a little while since I’ve updated this thread. So I got the back X/B pillar done, did the front engine bay bars, also added the top V and a middle cross bar. Getting very close to the chassis being fully setup! Just need to weld everything that’s in now all together.
More progress made yesterday. My dad installed the front hoops while I was working. After I got off, we worked together and got the main rear hoop in and added on down bar. Today, I’m sure we will be able to get the other down bar in and work on the tailgate/bed.
I just ordered some parts yesterday in order to get the tranny mounted and the axles in.. So, until those come in, I’ll be working on some body work (hood, Cowl and grill). Started yesterday by cutting down the CJ7 cowl. Had to do this because the hood + the cowl would of been way too long for the front of the chassis. While I worked on the cowl, my dad added a X up front to tie the shock hoops in for the leverage of the shocks, when those get mounted.
Today consist of cutting down my hood as well. Overall length of the original CJ7 hood is 39 1/4. I have to cut off 5 inches in order to make it fit on the chassis. Wish me luck! If I screw this up... I’ll be buying a new hood. Lol
Crazy that your nose will be that short. My hood was stretched 5-6", and I'll be using every bit of that for engine bay space. Your setup will probably make for much better forward visibility. I worry about that some...
It's cool that your hood and cowl are both square enough that you can cut out ten inches (?) and they still line up. Mine are both tapered.DIRTY DEEDS, DONE DIRT CHEAP
Originally posted by WrenchMonkey View PostCrazy that your nose will be that short. My hood was stretched 5-6", and I'll be using every bit of that for engine bay space. Your setup will probably make for much better forward visibility. I worry about that some...
