Project JimmyRig almost ready to begin.
  • #16
    It looks to me like it is a CAD. Kinda see the box on the backside.
    Is the rear a 70?
    1994 Dodge Ram 5.9L SWB
    • #17
      Originally posted by BIGRAM View Post
      It looks to me like it is a CAD. Kinda see the box on the backside...
      Real men aren't afraid to disco...
      • #18
        Looking at the picture again, if you trim right, make good radius cuts, and build some custom bumpers; it will look good as it should perform.
        I went and got more plasma jealousy last night as I'm cleaning the sami frame of brackets:(
        • #19
          Originally posted by mckeddie View Post
          just hauled a set of those out for scrap steel about 2 hours ago....
          why? :(
          sigpic
          • #20
            Is the rear a 70?
            definitely cad and good to go!
            sigpic
            • #21
              Originally posted by sarge View Post
              Don't have a clue what the wheel base will end up at , will find out when everything clears.
              Plan is to keep it streetable , thats why I'm going with Radial 37's
              It will be locked in the rear and I'm still debating on locking the front.
              Prolly have to recenter the H1's and I'm def. looking at rock rings
              Once I get the axles under her I'm gonna build front and rear bumpers, rocker protection and a nice flat belly.
              I have several different sets of leafs I'm going to be trying but I will probably end up with Dakota leafs in the front stockers in the rear with a possible extra leaf or two.
              What is your plans on locking the rear? I know your wanting to build on a budget as I am myself. I don't want to weld but I can't seem to find a spool for the rear.
              Also, what are the plans for the CAD? Vaccum sucks, you installing the cable kit or is there a home remedy for this? I have mine slid over in place but I don't like the front shaft spinning all the time or removing the box to release it. Thinking there has to be another way.
              • #22
                I used a switch to control the air flow and shift fork to engage and disengage the axle up front.
                sigpic
                • #23
                  Was the switch controlling the existiing vaccum or were you using a secondary source? Possibly compressed?
                  • #24
                    Used existing vaccum from motor. I do not remember which exact line I used but it is achievable with a little time.
                    sigpic
                    • #25
                      Cool. My vac lines failed me last year and it was aggrevating until I figured out what was going on. It may just be a leak but I don't have much faith in it now.
                      • #26
                        Huh. I thought I was the only one who did that:
                        Been runnin it for years. Works great for me...
                        • #27
                          No problems? I can deal with that. Thanks for the input fellas.
                          • #28
                            No problems?
                            Yeah, but like I said, I thought I was the only one.
                            Most people seem the hate the disco worse than brussels sprouts.
                            • #29
                              OK gonna answer a few of the questions , as I have been busy gathering the final parts for the past few days .... first off I need an Astro Van steering box from a 2wd van , anyone got one ?
                              The rear is a 60
                              Yes the front is CAD . not worried !;)
                              I'm going to run a cable from AW direct , just like I had in the wrangler $43.00 and forget it .
                              I'm welding the rear spiders
                              The transfer case is going to remain the factory 236GM unit for now. This will at least keep the build a little shorter and cheaper for now . Waiting for a 231C to roll into the yard and thinking of doing a 231/231 Doubler ??????
                              • #30
                                231/231 Doubler
                                interesting
                                01 TJ
