Grand Cherokee 1 ton build
  • #91
    Also got my fuel cell I ordered from RCI. Looks good. Plenty of room for the genright adapter
    • #92
      Got the genright adapter ring installed tonight. I used a ¼" drill bit for the holes and a jig saw with a metal blade for the big hole. I also put masking tape down to protect the cell.
      The gasket maker I used. Seemed thin but got sticky quick
      Put together
      If anyone uses this adapter put the gasket in the adapter NOT on the sender. Ask me how I know. :mad:
      All installed
      • #93
        Been trying to get back at it after the holidays and cold weather. Got the inner fender on passenger side almost done.
        Rough fit
        Also got all the fittings and steering column adapter. Hope to finish all of the steering up soon.
        • #94
          Got the fender well welded in
          All boxed in
          Cut the trim panel to fit. Don't know if I like where the pocket was since I had to cut it out. O well I want to have the trim in. At least from behind the seatbelt forward.
          • #95
            Got the jeep spun around in the garage this past weekend. Now I can start on the driver side rear fender.
            Took a break on the fenders to work on the steering a little bit. Got the new pump.
            Made templates for the orbital mount. Plan on using the steering gear mounting holes to bolt the mount to the frame
            And cut the steering shaft so it will slip in and out. It was pressed at the stock length. Grinded off the pressed part and now it slips
            Stock length 21"
            Collapsed to 16"
            Also had to file a little on the inner shaft cause it had some kind of a coating that made it to tight to slip easy.
            • #96
              Got the bracket for the orbital made up. It was harder than I thought it would be to fit it in there. It ended making the steering shaft a little closer to the header than I wanted but ended up good. If I would have angled it the orbital lines would have ran close to the belt.
              The reason for the bracket. The unibody has an offset where the steering box was.
              Test fit
              All mounted up
              Ran wire for the lengths of the hydro lines. Got them all mocked up.
              May run this one in front of the upper bracket. But there is more room than it looks.
              • #97
                Looks good nerd.
                • #98
                  Back on the fenders. Got the fuel door opening closed up. The opening had a rolled lip that made it easy to fit the filler piece in and weld. I completely welded the outside and put a lot of tacks on the inside on that lip.
                  The inside
                  • #99
                    Got the rear fenders done. The trim panel is trimmed.
                    How I think I'm going to set the tank. To keep room for the batteries. If they don't fit on the other side I'll center the tank.
                    Passenger side
                    When I get my battery boxes I'll see if they fit in the extra space. If not I'll back up and punt and try something else with them.
                      It's no white jeep bud, but looking good!!! I can't help but admire my handy work hahaha.......
                      • Originally posted by huntingmatt418 View Post
                        I hear you bud.
                        Still waiting on the battery boxes to show up but I splurged a little on the fuel cell. New artec hold down brackets.
                        • Got the front driver side fender done for the most part last night.
                          Stock
                          After cut out
                          Inside fender
                          From engine compartment
                          All painted up
                          • Passenger side.......what a mess. There is the fuse box-cruise control-a/c lines-hell there is even a battery temp sensor in the tray I have to figure out what to do with. :mad:
                            All the crap loose and out of the way
                            • All fenders are reboxed and painted.
                              Pass side engine bay. I plan on a high amp junction box for the hot leads.
                              And some fun stuff begins
                              Started laying out the winch plate and how to mount it. All the exo cage will tie in at the bumper and stinger in front.
                              Also got all the steering lines made at a local shop. Great prices and good people. Eagle equipment in franklin.
                              • That winch plate looks like it sits kinda low but i guess your rig sits a lot higher than mine. My winch plate will be even with the top of the bumper cover to maintain as much approach angle as possible. I might have it mounted by June if I'm lucky......
                                Still a real good looking build, hope we can get the twins together sometime this year?
                                Romans 7-8
