Those tires dry rotted yet? You have the body panels completed for it already correct? I like the angled guages! Wheres the radio going?
Looks nice CW... Pics never do this rig justice though.
That's more guages than I thought you would run, but glad to see them....
RPM, oil pressure, water temp, trans temp, volts... What's #5?
You order your switch panel yet? Custom or one of the standard ones?
I can't wait 'till you fire this thing up...brad
sigpic
Originally posted by KargoMaster View PostLooks nice CW... Pics never do this rig justice though.
I can't wait 'till you fire this thing up...sigpic
Working on it now whenever i can find a spare minute. Gotta get it done, it's killing me.
Finished the dash tonight, in aluminum of course. Decided the cardboard wouldn't hold up very well. Well, it's done except for the switch panel from Seabass. The white block represents where it will live... 12.5x3.5". Can't wait to see it.
Left ball valve will be front brake lock out, and the right one will be the rear. The look kinda primitive i guess, but they will get the job done, and don't have the drawbacks of the other lockouts i researched.
Closer shots of the ball-valve setups. They are simple Lance valves. I got them thru Afco, but they could be had at a lot of supply places im sure. They are stainless, etc, rated for high pressure hydraulics, not just water, etc.
I'm running the plastic race car line setup, as least temporarily for now. If nothing else it will be good for knowing how long to get my high dollar aeroquip lines made. Every bit of my brake system is 1/8 npt fittings, masters cylinders, all compression fittings, calipers, ball valves. Everything except my brake light switch, it has inverted flare. So i either need to find adapters or find a different brake light switch.
Got my valve covers bolted down finally, making me able to install the three braces in the engine compartment and start routing all of my hoses. So much little crap, ugh.
Originally posted by carwash View Postyeah, crossing my fingers... if they work for racecars, should work for us...
there are a few threads on pirate tho that argue otherwise.
legally, not sure. I know they are not as strong as a steel line, that's for sure. Compression fittings for hydraulic brake systems on commercial vehicles are not allowed.
I have heard of a few people that have broke a line during a panic 2 footed stop, etc. So, i'm not entirely sold on them, but i am using them for now.
Let me find the threads on pirate... i think i may have even started one...
